problems with labeling
rhkrhk
Post by rhkrhk » Wed Jan 16, 2013 6:17 am
Windows 7, SP1, 64 bit. Probably via installer.
Project: download LPs to hard drive.
Example: I record a Paul Robeson record, hit control M to get approximate divisions.
When finished, I remove some noise, move the marker to just before the song, (including the first song) and enter a label.
When I go to save as Flac files, I get a small screen that looks like an index card.
I enter Paul Robeson for the first song, but it doesnt carry forward to the next. Ditto for genre. HOW DO I GET THE PROGRAM TO CARRY THIS INFORMATION FORWARD?
After entering all of this manually, the program saves the flac files and I get an OK message that I downloaded, say, 6 songs.
The directory containing the music has 8-10 files - some with titles and 16-20K files - these are OK. Some files are untitled with only 1K, some are titled with only 1k.
I end up with maybe 3-4 useable files. What am I doing wrong?
Re: problems with labeling
Post by Gale Andrews » Wed Jan 16, 2013 12:48 pm
rhkrhk wrote:Windows 7, SP1, 64 bit. Probably via installer.
By reading the Manual
http://manual.audacityteam.org/o/man/me ... ditor.html
which says
When using Export Multiple, it's often easier to uncheck "Show Metadata Editor before export step" in Import / Export Preferences, then enter any tags common to all tracks at File > Open Metadata Editor... before exporting. Audacity will then add the automatically generated Track Title and Track Number tags for each exported file without the Editor appearing.
rhkrhk wrote: After entering all of this manually, the program saves the flac files and I get an OK message that I downloaded, say, 6 songs.
As waxcylinder said, you may have created a small region label by clicking then dragging in the track. You want to click to place the label, then do not drag but do CTRL + B to add the label (assuming the track is not playing).
Post by Gale Andrews » Wed Jan 16, 2013 12:51 pm
Also read this if you have not already done so:
http://manual.audacityteam.org/o/man/sp ... racks.html
NHL Guy
Post by NHL Guy » Thu Jan 17, 2013 4:48 pm
I had the same issue and accepted the fact I would have to type it each time. Following your instructions I now can carry all my information forward. All of the podcasts I do are interviews so I just need to change the guests name. Thank you so much for explaining it the way you did.
