Making Audacity be the default program for mp3
charlesh3
Post by charlesh3 » Mon Jan 07, 2013 5:45 am
Aftyer installation in Win 7 32 bit, Audacity does not apepar in the list of recommended programs that can be associated with mp3 file types as the default program. I click on "Browse" and then select Audacity.exe (in Program FilesAudacity) but nothing changes - Audacity does not become the default.
Any ideas what is wrong?
Chuck
Re: Making Audacity be the default program for mp3
Post by steve » Mon Jan 07, 2013 6:53 am
Did you previously have Audacity 1.3.x installed and associated with MP3 files?
charlesh3
Post by charlesh3 » Mon Jan 07, 2013 7:08 pm
Yes to having Audacity 1.X installed. As to whether it was the default program for mp3, I think so but am not 100% sure.
Chuck
Post by steve » Mon Jan 07, 2013 7:44 pm
charlesh3
Post by charlesh3 » Tue Jan 08, 2013 2:42 am
Thanks Steve, that took care of it. I chose the wrong search words and did not find that post.
Chuck
