Effects Installed Not All Working
DJ Kytrooper
Hello everybody I'm kinda new here so don't judge if this turns out to be a stupid question with an obvious solution. Recently I installed some effects: (the names are the names of the folders they are in) bjflanger, bjlofi, bjovrdrv, bjrngmod, bjtremlo, bjwavech2. I did not extract the files, which normally I do, but the effects showed up anyway without it. The ones that worked are bjlofi, bjovrdrv, bjrngmod, and bjtremlo. The two that didn't work are the ones I was looking most forward to!!! I tried seeing if it would work on Bj Flanger if I extracted the files into the plug-ins, but it made no difference. The files are VST effects. I saved them under Audacity Plug-ins.
- Quality Assurance
Re: Effects Installed Not All Working
You can't expect plug-ins to work if you leave them in the zip.
The WaveChanger v2 and bjflanger work OK for me in current Audacity 2.0.2.
Try the installer and/or WaveChanger v3 here http://www.bojo-software.com/. Don't change the installer path then it should work.
Instructions to install VST plug-ins are here http://wiki.audacityteam.org/wiki/VST_P ... n_Audacity .
DJ Kytrooper
I didn't leave them in zip files. I exported the zip file BJ (i think) and it contained a lot of normal folders (not zip) with the effect names. I wasn't sure whether to extract them or not. It works better if I actually DON'T extract from the normal folders, which surprised me, but two effects didn't show up when I rescanned Audacity.
And thanks for the Wavechanger thing but I really want BJ Flanger. I got the effects off the VST Plug-Ins from the Audacity Wiki.
I just noticed it is a .dll file does that have anything to do with it?
- Quality Assurance
You can't have any items still in zip files, but some effects may require to be kept in their own folder. That should not be a problem. When Audacity checks a folder that it is supposed to check for VST effects ( see here for the folders it looks in ) then it also looks in other folders within the folder it checks.DJ Kytrooper wrote:I didn't leave them in zip files. I exported the zip file BJ (i think) and it contained a lot of normal folders (not zip) with the effect names. I wasn't sure whether to extract them or not. It works better if I actually DON'T extract from the normal folders, which surprised me, but two effects didn't show up when I rescanned Audacity.
As I said, I explicitly tested BJFlanger. The version I found to work was in this installer http://www.bojo-software.com/downloads/ ... lugins.exe .I really want BJ Flanger.
It has to be a DLL or Audacity won't do anything with it.I just noticed it is a .dll file does that have anything to do with it?
