Error opening sound device...
dexxor
Post by dexxor » Sat Dec 29, 2012 3:13 pm
Hi,
So there have been a lot of posts on this, but no solutions as yet for me...
I've tried everything @ http://manual.audacityteam.org/o/man/fa ... vice.22.3F
Basically either after pressing record or 2/3 minutes of recording, the message pops up. [Error while opening sound device. Please check the input device settings and the project sample rate]
This also completely shuts down all sound functionality on my laptop... but will normally right itself after a reboot.
I'm recording via a pretty basic Logitech microphone and using an "IDT High Definition Audio CODEC" as a sound controller...
Any advice?
Re: Error opening sound device...
Post by steve » Sat Dec 29, 2012 5:18 pm
dexxor wrote:I'm recording via a pretty basic Logitech microphone
Is that a USB microphone or does it plug into your sound card?
What settings do you have in the Device Toolbar?
dexxor
Post by dexxor » Sat Dec 29, 2012 5:22 pm
It plugs into the sound card.
Device toolbar is currently @ MME : Speakers/Headphones (IDT High : Microphone/Line In (IDT High : 1 (Mono) Input Channel
Post by steve » Sat Dec 29, 2012 5:30 pm
What sample rate do you have set in:
1) Audacity; "Edit > Preferences > Quality"
2) The recording settings in the Windows Sound Control Panel
dexxor
Post by dexxor » Sat Dec 29, 2012 5:35 pm
Audacity: 44100Hz (24bit)
Windows Sound: 44100Hz (2 channel, 24bit)
Post by steve » Sat Dec 29, 2012 5:48 pm
Try these settings with both Host = MME and Host = Direct Sound:
Audacity to 44100 / 32 bit (float)
Windows Sound: 44100Hz / 1 channel / 16bit
dexxor
Post by dexxor » Sat Dec 29, 2012 6:26 pm
Not able to set Windows Sound to 1 channel.
All other settings changed. Will test and post back. Preliminary tests are looking good :D
dexxor
Post by dexxor » Sat Dec 29, 2012 8:36 pm
Tested on and off for around 4 hours now... seems to have worked! Thanks for your speedy replies!
Happy New Year! :mrgreen:
sdatta8388
Post by sdatta8388 » Sun Aug 24, 2014 7:36 pm
I have tried all of these things on the Wiki and what you just suggested and I am having the same problem. However, instead of shutting down mid-recording, it doesn't even let me record. Really frustrated! I was recording with the mic and then all of a sudden I opened up a new Audacity window and it wouldn't let me record with the mic anymore and kept giving me the error. Any help would be appreciated.
Post by Gale Andrews » Mon Aug 25, 2014 5:59 pm
sdatta8388 wrote:I have tried all of these things on the Wiki and what you just suggested and I am having the same problem. However, instead of shutting down mid-recording, it doesn't even let me record. Really frustrated! I was recording with the mic and then all of a sudden I opened up a new Audacity window and it wouldn't let me record with the mic anymore and kept giving me the error. Any help would be appreciated.
It is much better to start a new post rather than jump on someone else's post. The other person probably has a different system to you.
See if this helps: FAQ:Errors - Error opening sound device .
If you need more help please state your version of Windows and your version of Audacity (all three numbers from Help > About Audacity... ). Give us the exact make and model number of the microphone.
