When ever I try to play back a certain song it says "Error while trying to open sound device. Please check output device settings and project sample rate" How exactly do I check this?
I'm pretty sure my computer is Windows 7.
Any help would be greatly appriciated
Won't let me play back
- Quality Assurance
Re: Won't let me play back
Please try the steps in this Frequently Asked Question:AnnaBee wrote:When ever I try to play back a certain song it says "Error while trying to open sound device. Please check output device settings and project sample rate" How exactly do I check this?
http://manual.audacityteam.org/o/man/fa ... und_device .
Also check the input devices while you are there if you are intending to record anything.
