CD track # ID
CD track # ID
After creating, editing and saving a recording I can't get the file to recognize divided clips into 'track numbers' (for the various songs). When saved and burned to a CD, only "Track 1" appears and the file is continuous, not separated into tracks as in a typical CD. I have created 'Silent spaces between the songs and, via Edit>Clip Boudaries> Detach at Silences I separated the songs identifying each as a track, which is what I want to see when (after burning the CD) playing the new CD on my Bose player.
waxcylinder
Re: CD track # ID
see this tutorial in the manual: http://manual.audacityteam.org/o/man/sp ... racks.html
and: http://manual.audacityteam.org/o/man/bu ... _a_cd.html
