hi where in audacity can you change the sample rate and bit depth?
lenny
changing the bit depth and sample rate
coonsanders
Re: changing the bit depth and sample rate
If you are recording, the default sample rate and sample format are in preferences:
Edit > Preferences > Quality
If you mean something else, please describe the job.
coonsanders
that reminds me..you cant control the vu meters as the music going into your line in on your soundcard so how do you con-
trol the sound after you save the file and add a title to the music file..?
lenny
lenny
If you wish to ask a new, unrelated question, please start a new topic, otherwise it becomes very confusing
Did my first reply adequately answer your original question?
coonsanders
it did thanks..
