Obtain crackly/radio type effect
TheKillerQueen
Post by TheKillerQueen » Wed Nov 21, 2012 12:23 am
Hello my fabulous experts!
A very quick and easy question...
I want to make some of my vocals sound like a plane radio/crackly type noise..
Ive read around on google and people have said play about with equalization and compression, but I can't get it to sound right. any ideas?
Re: Obtain crackly/radio type effect
Post by steve » Wed Nov 21, 2012 1:21 am
Try a combination of the Leveller effect (on a "heavy" setting) and something like the "Telephone" setting in the Equalization effect.
http://manual.audacityteam.org/o/man/ef ... l#leveller
http://manual.audacityteam.org/o/man/equalization.html
Post by kozikowski » Wed Nov 21, 2012 2:10 am
It's the crackly noise where I got stuck.
I loaded a 10 second segment of brown noise. What I want is just the peaks of the noise to force themselves through like in an airliner radio several miles out. There doesn't seem to be any setting of Noise Gate that will do that, but it should. I should be able to make all the noise below, say, -12 (most of it) to drop to zero with just the 0 to -12 peaks remaining.
There's some other tricks to get that sound, but the rest kind of depend on that working.
TheKillerQueen
Post by TheKillerQueen » Wed Nov 21, 2012 12:40 pm
It does seem to be more difficult than made out, i also think it depends on what you use to record perhaps. All the youtube videos make it look easy. When they change the equalization, there sound gets bigger, mine gets smaller, yet i follow exactly what they do.
Maybe I could try a sort of distorted megaphone effect? If anyone knows how?
Post by kozikowski » Wed Nov 21, 2012 4:00 pm
Point to one or two.
TheKillerQueen
Post by TheKillerQueen » Thu Nov 22, 2012 4:13 pm
Shaky
Post by Shaky » Thu Nov 22, 2012 5:56 pm
There is a free VST effect called 'Vinyl' that emulates the crackly sound from old records.
You might be able to get a sound you can use with that, but just take care to decline the crapware the installer tries to set up.
See http://tonebytes.com/vinyl/
TheKillerQueen
Post by TheKillerQueen » Thu Nov 22, 2012 5:59 pm
Shaky wrote:There is a free VST effect called 'Vinyl' that emulates the crackly sound from old records.
Thanks Shaky, I shall give it a go!
Post by steve » Thu Nov 22, 2012 6:04 pm
There is also a Vinyl effect in the "LADSPA Plug-in Pack" http://audacityteam.org/download/plugins
TheKillerQueen
Post by TheKillerQueen » Thu Nov 22, 2012 6:16 pm
steve wrote:There is also a Vinyl effect in the "LADSPA Plug-in Pack" http://audacityteam.org/download/plugins
thanks Steve, the other one doesnt seem to be compatible.
