FFmpeg imports mono tracks as stereo[SOLVED]
marco.stanzani
Post by marco.stanzani » Tue Nov 06, 2012 11:41 am
for saving space and *before* conversion to AAC by FFMPEG. very easy in principle, looking here http://wiki.audacityteam.org/wiki/Talk: ... ur_Project
still, if I save the mono track and re-open it I still se two channels. I cannot fine any oprion which sets the mono bit in the AAC file
If i do the same using the mp3 lame encoder I can see just one track in audacity when re-reading the saved fil
thanks for your help
I am 2.x and W7
Last edited by marco.stanzani on Fri Apr 24, 2015 4:07 pm, edited 2 times in total.
Reason: Changed title
Re: convert stereo to mono
Post by steve » Tue Nov 06, 2012 2:49 pm
To convert a stereo track to mono in Audacity 2.x,
Select the track, then "Tracks menu > Stereo Track to Mono"
http://manual.audacityteam.org/o/man/tr ... eo_to_Mono
DVDdoug
Forum Crew
Post by DVDdoug » Tue Nov 06, 2012 7:30 pm
...for saving space and *before* conversion to AAC by FFMPEG.
I wouldn't want a "fake" stereo file, but I don't think you'll save space by saving a mono file as mono AAC. AAC uses Joint Stereo by default, which encodes the L+R & L-R signals separately. With mono, there is no sound in the L-R "channel", and AAC (and MP3) are "smart enough" not to waste space when there is nothing to encode, so you are only encoding one channel's worth of information.
Post by Gale Andrews » Wed Nov 07, 2012 6:36 am
marco.stanzani wrote:if I save the mono track and re-open it I still se two channels. I cannot fine any oprion which sets the mono bit in the AAC file
Update to the currently recommended FFmpeg 0.6.2 ( http://manual.audacityteam.org/o/man/fa ... tml#ffdown ) then it will import mono AAC files as mono.
marco.stanzani
Re:FFmpeg imports mono tracks as stereo[SOLVED]
Post by marco.stanzani » Wed Nov 07, 2012 4:49 pm
thanks, it works! and yes, saving mono files will save 50% of space approx (as expected)
