Since I installed Windows 7 Ultimate 64-bit, Audacity does not work. Can't cut, copy, paste, select, etc.
Totally baffled and frustrated since I like to use Audacity frequently.
Thanks in advance for helpful replies.
SC
Help! Audacity not working!
Re: Help! Audacity not working!
Why not? What happens?StarCapt wrote: Can't cut, copy, paste, select, etc.
Which version of Audacity do you have (Look in "Help > About Audacity")
- Quality Assurance
