Running Lame
nigelnash
Running Lame
Post by nigelnash » Thu Oct 25, 2012 11:20 am
My laptop and PC both run Windows 7 and I have downloaded the Lame programme to concert to MP3, but in both cases the programme will not load, might there be a conflict somewhere? I tried downloading the alternative 3.98.4 build but got a message saying Insufficient Permissions
Re: Running Lame
Post by steve » Thu Oct 25, 2012 2:17 pm
First check that you followed the instructions as described here exactly, and if there is still a problem try the troubleshooting tips: http://manual.audacityteam.org/man/FAQ: ... g-Ins#lame
DVDdoug
Forum Crew
Re: Running Lame
Post by DVDdoug » Thu Oct 25, 2012 8:06 pm
I've never had that problem, but there are many other LAME-based encoders. It's an extra step, but you can save-as (export to) WAV, and then use another program for MP3 encoding.
XRECODE (FREE!!!) or XRECODE II ($15 USD) are handy for all kinds of audio conversions.
Or, you can use LameDrop (FREE!!!), or HydrogenAudio has a list of free LAME "front ends" on this page.
Or, you can use LAME.exe directly from the command line.
Re: Running Lame
Post by steve » Fri Oct 26, 2012 12:24 am
Lamedrop is good for batch encoding if you have a load of WAV files to convert. Just drag and drop them onto the fish and make yourself a cup of tea (or coffee) while it gets on with the job.
