Audio Cassette - Recording
Re: Audio Cassette - Recording
Post by steve » Mon Oct 22, 2012 10:51 pm
eager to learn wrote:SoundMax HD Audio: Microphone
That one is wrong - The recording input should be "SoundMax HD Audio: Line In" (as in your screenshot).
eager to learn
Post by eager to learn » Mon Oct 22, 2012 11:16 pm
Steve,
I had it set to SoundMax HD Audio: Line In but the sound never registered with Audacity.
The L/R sound level bars just sat there.
Thanks.
Post by steve » Tue Oct 23, 2012 1:20 am
Check in the Windows mixer that the "line in" is enabled for recording, not muted, and the recording level is turned up.
http://wiki.audacityteam.org/wiki/Mixer ... ssues#xpcp
eager to learn
Post by eager to learn » Tue Oct 23, 2012 7:31 pm
Steve,
This is what I see (2 attached screen shots in jpg)
XP - Volume Settings - Not Muted.JPG (36.67 KiB) Viewed 925 times
XP - Audio Settings - Audio Tab.JPG (41.79 KiB) Viewed 925 times
Post by steve » Tue Oct 23, 2012 7:59 pm
Could you post a picture of the recording settings.
Click on the "Volume" button in the "Sound Recording" section of your second picture. It will look something like this:
eager to learn
Post by eager to learn » Tue Oct 23, 2012 8:43 pm
Looking in the Advanced Volume I noticed Line In was not checked so I placed a check mark next it and it removed the check mark next to Microphone.
I then hit play on my cassette deck and clicked the Microphone icon in Audacity and hit the purple button to record and then stopped it after about 30 seconds.
I then clicked File > Export and chose WAV (uncompressed).
I then visited where I saved that file on the hard drive and clicked to play it using Winamp and with the speakers turned up I heard nothing.
Hmmm....
Post by Gale Andrews » Wed Oct 24, 2012 2:03 am
eager to learn wrote:Looking in the Advanced Volume I noticed Line In was not checked so I placed a check mark next it and it removed the check mark next to Microphone.
That is a good sign, selecting one input disables the other.
eager to learn wrote: I then hit play on my cassette deck and clicked the Microphone icon in Audacity and hit the purple button to record and then stopped it after about 30 seconds.
DId you record a flat line or a blue waveform with peaks and troughs like this:
eager to learn
Post by eager to learn » Wed Oct 24, 2012 5:22 pm
Hi Gale,
It seemed to record with a flat blue line and there was a thin red vertical line as well.
I get the distinct impression I will need to adjust something?
Thank you for your help.
Post by Gale Andrews » Wed Oct 24, 2012 8:48 pm
If you set Device Toolbar as you had it before:
then Audacity should record, if you also have the right-hand (input) slider on Mixer Toolbar turned up:
eager to learn
Post by eager to learn » Wed Oct 24, 2012 8:54 pm
Gale,
You are so awesome.
Worked perfectly.
Thank you so much!
