Plot Spectrum drop-down settings not sticking
TheKMan
Re: Plot Spectrum drop-down settings not sticking
Post by TheKMan » Mon Oct 22, 2012 10:37 am
Forget it. I'll just keep selecting the options each time I Plot Spectrum.
Head.
Hurts.
Too.
Much.
Code!
Post by Gale Andrews » Tue Oct 23, 2012 4:28 am
TheKMan wrote:Forget it. I'll just keep selecting the options each time I Plot Spectrum.
You shouldn't need to. No else has to. And we can't do anything about it if we can't make it happen.
In case the .cfg file got corrupted, I would File > Exit Audacity. Run the installer again with "Reset Preferences" checked. Then try again.
TheKMan
Post by TheKMan » Tue Oct 23, 2012 4:20 pm
Gale Andrews wrote:
TheKMan wrote:How did I reset preferences?
Per Steve's instructions(dated October 10):
If you are using the current Audacity 2.0.2 installer there is an option to reset preferences. Audacity 2.0.2 is available here: http://audacityteam.org/download/"
OK, so if you did that reset after choosing your settings in Plot Spectrum, you would have wiped those settings changes out. Is that what you did? If not, read on.
TheKMan wrote:As far as "audacity.cfg" is concerned, I've tried searching high and low for that thing.
  1. Launch Audacity, then in Plot Spectrum, set Size to 2048 and Axis to "Log", exit Audacity
  2. Follow these steps to show hidden files and folders http://windows.microsoft.com/is-IS/wind ... dden-files
  3. Navigate in Explorer to Users<your user name>AppDataRoamingAudacity (note, replace <your user name> with whatever your user name is)
  4. Right-click over audacity.cfg > Copy. CTRL + V to paste "audacity - Copy.cfg" into Explorer. Select "audacity - Copy.cfg", press F2 and rename the file to "audacity - Copy.txt" (without quotes)
  5. Follow the steps here http://forum.audacityteam.org/viewtopic ... 49&t=64936 to attach "audacity - Copy.txt" to your reply.
Good news! As of this reply the settings are sticking in Spectrum. Size = 2048 and Axis = Log Freq. I did not do anything different. I just reopened Audacity and the settings are as I left them yesterday.
Welcome to "Veesta" Gale - do you have what it takes?
