How can I modify the audacity's interface(edit audacity.rc?)
cwl007
Post by cwl007 » Fri Oct 19, 2012 2:38 am
How can I modify the interface? I think I should modify audacity.rc, but when I try to open it , it shows a error that can't be opened. How do I deal with it or provide other suggestion,thanks!
Re: How can I modify the audacity's interface(edit audacity.
Post by Gale Andrews » Fri Oct 19, 2012 4:26 am
cwl007 wrote:How can I modify the interface? I think I should modify audacity.rc, but when I try to open it , it shows a error that can't be opened. How do I deal with it or provide other suggestion,thanks!
Please be much more specific about what you want to change.
This is all that audacity.rc controls (these contents show in Explorer's "Details" property sheet for audacity.exe)
Code: Select all
CompanyName", "The Audacity Team"
"FileDescription", "Audacity®, the Free, Cross-Platform Sound Editor"
"FileVersion", AUDACITY_FILE_VERSION
"InternalName", "Audacity"
"LegalCopyright", "Copyright © 2021. All rights reserved."
"LegalTrademarks", "Audacity® is a registered trademark."
"OriginalFilename", "Audacity.exe"
"ProductName", "Audacity®"
"ProductVersion", AUDACITY_FILE_VERSION
Changing that RC file will have no effect unless you recompile Audacity or access its contents some other way (for example, with a resource editor).
cwl007
Post by cwl007 » Sun Oct 21, 2012 12:02 pm
Thanks. I want to modify audicity's original interface, for example, delete some menu.
I think I can do it by comparing modifying VC project's rc as the attachment.
But it show errors that I couldn't open it.
cwl007
How can I modify audicity's rc throwing visualization tool
Post by cwl007 » Sun Oct 21, 2012 1:04 pm
How can I modify audicity's rc throwing visualization tool.(In MFC you can modify interface by editing visual rc)
Reason: Topic merged with existing thread.
Post by steve » Sun Oct 21, 2012 10:15 pm
cwl007 wrote:Thanks. I want to modify audicity's original interface, for example, delete some menu.
See this article: http://manual.audacityteam.org/index.ph ... g_Audacity
