RAX Audio File
raineri4
RAX Audio File
Post by raineri4 » Wed Oct 17, 2012 10:19 pm
Is there a way to convert these files from Rhapsody to a .wav or .mp3 file through Audacity or other sources out there? Thanks.
Re: RAX Audio File
Post by steve » Wed Oct 17, 2012 10:32 pm
I doubt that Audacity can help you.
.RAX files are DRM protected.
If you have a license for the files you may be able to create an audio CD of them with Windows Media Player, then rip that CD to the format that you require.
Re: RAX Audio File
Post by Gale Andrews » Thu Oct 18, 2012 3:37 am
It's possible to record any files into Audacity as they play, if your machine supports this ( see http://manual.audacityteam.org/o/man/tu ... ndows.html ). This would be slightly lossy, but burning an audio CD would be lossless.
You should only record the files if you have the licence for them but cannot use it (because RAX is no longer supported or some other technical reason).
