Recording
earlgrey
Recording
Post by earlgrey » Wed Oct 17, 2012 6:07 pm
any other examples of a good cassette player suitable for playing into Audacity? I'm always looking for better stuff and all.
Re: Recording
Post by steve » Wed Oct 17, 2012 6:18 pm
Topic split.
Please do not hijack other conversations - if you have an unrelated question, please start a new topic.
Any good cassette player can be used for playing into Audacity. Many of the best cassette players were made by Nakamichi. If you are using a conventional cassette player you will also need a sound card that has stereo line level inputs.
earlgrey
Re: Recording
Post by earlgrey » Fri Oct 19, 2012 5:09 pm
I apologize for that. I was trying to get my post under the one discussing the kind of mic they used and how you should use a good one.
