Troubleshooting
suunchild
Troubleshooting
Post by suunchild » Fri Oct 12, 2012 6:10 pm
I am trying to edit a track but when I select the section that I want to delete the functions in the "Remove Audio" drop down are not available. Please advise. Thanks
Re: Troubleshooting
Post by steve » Fri Oct 12, 2012 6:13 pm
Make sure that playback is stopped and not just paused. (press the Stop button with the yellow square).
suunchild
Re: Troubleshooting
Post by suunchild » Fri Oct 12, 2012 10:03 pm
That did it. Much Thanks
