I just downloaded Audacity. I want to edit the audio that’s on a powerpoint show.
It’s a .wav file. I no longer have the audio separate from the video.
I can’t get the audio into Audacity. How do I do that?
Thanks.
If the problem is that you can’t extract the WAV file from the PPT file, see if this helps: http://labnol.blogspot.co.uk/2006/11/sound-powerpoint-tip-extract-audio.html
