pfeuh wrote:Gale Andrews wrote:Please recheck by double-clicking the click track then the recorded track and comparing the length in Selection Toolbar at the bottom.
The len of the click track is 4.000sec. I have recheck the recorded track (4.010 seconds).
OK that is normal (the actual recording is slightly longer than the selected area).
The workaround for losing the last note of your overdub recording is easy - either hover over the end of the selected track and drag the selection another 130 ms to right (or whatever distance the latency is), or click underneath the tracks to remove the selection then stop the recording manually.
pfeuh wrote:Gale Andrews wrote:Usually when you record just the selected area (which happens when Transport > Overdub is "on")
I use Audacity in french,
You do have "Overdub" set to "on" (ticked); "Overdub" is called "Doublage" in French. So if you have a selection made in Audacity and you record with "Overdub" enabled, Audacity records for a fraction more than the length of the selection, then stops.
pfeuh wrote:I have tried to uninstall/reinstall in english, I had failed, it could be another topic
You can change language in the "Interface" Preferences:
http://manual.audacityteam.org/o/man/fa ... l#language .
pfeuh wrote:In my opinion, a track shifted because of latency should be automaticaly converted to a regular track (that means without the symbol '<-' ) as soon as it is recorded. But I suppose it causes more problems than it solves.
Recordings will always be laid down after playback, so if the recording starts at time zero it must be pushed behind zero in order to synchronise (sync) with the other tracks.
The issue you have correctly identified is that if tracks are synced when some tracks are behind zero and some starting at zero, then to keep all tracks synced, the audio behind zero should not be exported.
- Export does not export audio behind time zero.
- Export Selection exports exactly what is selected, so if you select the audio behind zero by double-clicking the track, the audio behind zero will be exported; if you select from time zero to the end of the track, the audio behind zero is not exported.
- Export Multiple does export behind time zero.
- You cannot configure the behind zero behaviour for Export or Export Multiple.
pfeuh wrote:You mean if somebody create a track begining at the middle of the project instead of time 0.0, exportation should fill with zeros before?
That is another issue again, as I already remarked. As all export methods are now, the white space between zero and the start of the audio will be disregarded. If you want that space preserved in the export, you must select from the start of the recording to time zero and generate silence. There are already eight votes for there to be a global preference for all types of export to export the space before the start of a track as leading silence.
steve wrote:I therefore think that including (or not) before zero audio needs to be an option that is available in the Export Multiple dialogue.
Two votes have already been added to Feature Requests for that. But I'm thinking this is a potential problem with straight export too, so if a global export preference is too "undiscoverable", the standard export dialogue would need the same checkbox (greyed out if exporting the selection).
