Audio Quality Drops With Another Program Open
HateAudioIssues
Operating System: OS X 10.10 Yosemite
Post by HateAudioIssues » Wed Sep 19, 2012 6:48 am
I'm using Windows 7. Audacity 2.0 of course.
I'm using turtle beach x11's. I recently reset my laptop due to a trojan. For some reason my recording differs from time to time when I have a program open. For example, Sony Vegas and ArcSoft Biz. This problem never occurred before.
To go further, I'll do a quick mic check, everything will be fine. But as soon as I open the program, my voice comes out terrible. The quality drop is very noticeable.
Example = Good audio (where I want to get back to) http://www.youtube.com/watch?v=0Re0TGCc ... dded#t=16s
Example = Bad Audio http://www.youtube.com/watch?feature=pl ... 7X0#t=684s
Any thoughts or fixes? I've tried giving audacity priority, resetting the drivers, disabling the stereo mix (didn't work), playing with the exclusive mode, nothing works. As soon as I open any of those two programs my recording dips.
Edit: Fixed the links
Last edited by HateAudioIssues on Wed Sep 19, 2012 8:46 pm, edited 1 time in total.
Re: Audio Quality Drops With Another Program Open
Post by steve » Wed Sep 19, 2012 1:06 pm
Your two links are the same, but I think I know what you mean. The problem is simple, but unfortunately the solution is not so clear cut. When the other program is running, your computer is failing to deliver a continuous stream of audio data to the hard drive, so tiny bits of the audio are missing. This literally makes the sound "break up" and sound terrible. The solution may be as simple as defragmenting your hard drive (a fresh install of Windows will often produce a large amount of fragmentation), or you may just need to update your drivers. Ensure that Windows and all of the hardware drivers are fully updated, then defragment the hard drive and reboot. If the problem persists, see here for some other suggestions: http://wiki.audacityteam.org/wiki/Manag ... nd_Drivers
Post by steve » Wed Sep 19, 2012 9:09 pm
There is some distortion in the "bad example". Something is being overloaded - either the recording level is too high, or you are too close to the microphone, or you're getting excited and talking too loud, or you have pushed up the level too high when editing, or .....
See the flat top to the waveform in the selected area - the top / bottom of the waveform is cut off:
HateAudioIssues
Post by HateAudioIssues » Wed Sep 19, 2012 9:27 pm
Prior, I had my input volume set to 0.4, now I have it at 1.0 just simply because 0.4 since I removed the trojan is way too quiet.
And sorry I didn't understand the image, could you dumb down your suggestion to me?
Post by steve » Thu Sep 20, 2012 12:18 am
I have downloaded the Prison Island video and imported the audio into Audacity.
Zooming in really close at about 3 minutes 17 seconds:
See how the waveform is so big that it does not fit in the track - the top and bottom of the largest peaks are being "chopped off" (clipped) and this causes audible distortion.
HateAudioIssues
Post by HateAudioIssues » Fri Sep 21, 2012 10:53 pm
So I tried lowering my input, issue came up again today if I open up Sony Vegas or Arcsoft Biz. Like I'll record 5 seconds, it'll be fine, then open up either program and the audio comes out a lot more hallow and drops the next 5 seconds. There must be a solution to this.
I tried moving the mic away from me, issue came up still.
Post by Gale Andrews » Fri Sep 21, 2012 11:48 pm
You will need to try the list of suggestions in the link Steve gave http://wiki.audacityteam.org/wiki/Manag ... nd_Drivers .
What did you do when you reset the laptop? A System Restore? A reinstall of Windows may be a good idea (back up your data, but you should be able to reinstall Windows to keep your program and settings as per http://www.sevenforums.com/tutorials/34 ... stall.html ).
HateAudioIssues
Post by HateAudioIssues » Sat Sep 22, 2012 5:18 am
Gale Andrews wrote:You will need to try the list of suggestions in the link Steve gave http://wiki.audacityteam.org/wiki/Manag ... nd_Drivers .
I used tweaking.com window's repair. I just updated my drivers and found the same issue was occurring again. I tried of solutions on that list none of them seem to work. I uninstalled and reinstalled audacity, problems still there. The recording is fine until the moment I pulled up one of those two programs.
Post by steve » Sat Sep 22, 2012 10:39 am
HateAudioIssues wrote:The recording is fine until the moment I pulled up one of those two programs.
So you're saying that it looks pretty clear that those two programs are causing the problem?
What programs are they?
HateAudioIssues
Post by HateAudioIssues » Sat Sep 22, 2012 3:25 pm
Sony Vegas and ArcSoft Biz. I'm sure other programs with sound (perhaps even listening to a youtube video) would conflict with my mic input.
