Can't get LADSPA plugins to work.
Thunderbolt1000T
Post by Thunderbolt1000T » Tue Sep 18, 2012 9:03 pm
I installed the set of LADSPA plugins for Windows, but none of them are showing up in the Effect menu. In Prefferences, I have LADSPA enabled. How do I get them to show up?
Re: Can't get LADSPA plugins to work.
Post by Gale Andrews » Tue Sep 18, 2012 10:18 pm
Have you installed the plug-ins in Audacity's "Plug-ins" folder?
Have you restarted Audacity?
