Running Audacity 2.0.2 on Vista Service Pack 2. Installed Audacity from a disc that came with a USB turntable...upgraded to 2.0.2 online with exe.
Audacity works fine, but ever since installation, I can't get any audio out of any other players...Windows Media Player, Realplayer, etc.
Internet audio (Youtube,etc) is OK. Vista speaker tests work fine.
Has this happened to anyone else?
Audacity Overriding Other Media Players
Yaklovitch
Re: Audacity Overriding Other Media Players
This is probably the issue: http://manual.audacityteam.org/man/FAQ:Playback#usb
Yaklovitch
Bingo.steve wrote:This is probably the issue: http://manual.audacityteam.org/man/FAQ:Playback#usb
Gracias, Steve.
