Looking for a vocal effect which sounds like your far away
Birkoner
Post by Birkoner » Sat Sep 08, 2012 7:06 pm
I read something about an effect that sounds like you are in a room or far away, like an echo in a room. Not sure if it was on this forum or not, im doing a song called Time Machine, and need an effect that sounds like im in a small area or something to that nature...any suggestions would help.
Re: Looking for a vocal effect which sounds like your far aw
Post by steve » Sat Sep 08, 2012 8:02 pm
Use the Equalization effect to reduce high and low frequencies, then apply some reverb.
Some links to help:
http://manual.audacityteam.org/o/man/equalization.html
http://wiki.audacityteam.org/wiki/GVerb
Birkoner
Post by Birkoner » Sat Sep 08, 2012 8:15 pm
Thanks Steve
