Waveform missing upon import
snookerjulian
Post by snookerjulian » Wed Sep 05, 2012 4:13 pm
Hi, I'm using Audacity 2.0.(whatever was latest May/June 2012) on Windows Xp Home.
When i try now to import mp3 or wav files, either by using import in the file menu, by clicking and dragging or just 'open' Audacity appears to perform my request as normal, taking the appropriate amount of seconds or minutes, with NO error message, a new project is created as normal with the stero tracks within, all text data in tact but with only one thing missing, there is no waveform, just the horizontal line!
These files have been imported before and some of which are stereo mixes of multitrack projects (which i have kept for future editing if needed so aren't lost) but it seems i can now only work on existing projects, I don't want to mix my multitracks down to stereo permanently but make exported copies occasionally to listen on my car speakers and maybe compress/limit/eq etc stereo files, now I can never re import them back into Audacity. These files play fine on othe media players ie. wmp and vlc and my mobile phone, which suggests there is music therein?
Another problem is I used to be able to to copy and paste tracks of audio into new separate projects (to make sub-mixes or work on layered vocals alone for example) and now i have the same problem, all that pastes is a track with the track name and no waveform. It only seems i can 'duplicate' within the same project.
All of these things were possible up until yesterday, hopefully I've just accidentally clicked something I shouldn't and theres an easy remedy, please help,
Thanks in advance.
Julian
Re: Waveform missing upon import
Post by kozikowski » Wed Sep 05, 2012 4:44 pm
Do a screen grab and post what it looks like when the import fails. Does it look more or less like this except the blue line is flat instead of wavy?
http://kozco.com/tech/audacity/Audacity1_playback.jpg
Do you have the same !.0, 0.0, -1.0 for each track that I have in the illustration?
It does not play, right? No bouncing green meters?
What happens if you're in one of these failures and you Generate Tone or other sound? Does it arrive?
Posting Instructions:
http://forum.audacityteam.org/viewtopic ... 49&t=64936
Post by steve » Wed Sep 05, 2012 4:47 pm
How strange.
Try this file, does this show up and play? (it's just a short "beep")
beep.wav
(430.71 KiB) Downloaded 154 times
Post by kozikowski » Wed Sep 05, 2012 5:10 pm
Yes, try managing music that you didn't make. Koz
snookerjulian
Post by snookerjulian » Wed Sep 05, 2012 5:46 pm
Thanks for the prompt response, I'm not home currently and using a work computer and will give as much detail as soon as I can but from memory everything is exactly as it should be but its as though the whole project has had its audio silenced, exactly as the example but a flat blue line which plays nothing and doesnt make the meters bounce. As for generating tone or adding your beep Steve I'm not sure, I will try later and respond with the results.
It might be worth pointing out my laptop is eight years old and I cleared out some temporary files in the hope it would run quicker though I'm sure all Audacity's functions have been ok since I did this and before this problem.
Thanks again
snookerjulian
Post by snookerjulian » Wed Sep 05, 2012 6:00 pm
I will try and rip something from a cd, I did try with a rip I made a couple of weeks ago but again, just horizontal blue line and an other wise perfect import.
Post by kozikowski » Wed Sep 05, 2012 8:56 pm
It's worth a shot. You could have inadvertently forced Audacity to use very old and out of date or damaged preferences.
Try resetting them (scroll down).
http://manual.audacityteam.org/o/man/preferences.html
snookerjulian
Post by snookerjulian » Thu Sep 06, 2012 11:53 am
Thanks for the advice, tried to generate tones import and and record new audo within one of these failed projects, and any audio created seems to vanish immediately. I pushed a jack in and out of the microphone socket to create clicks and a waveform appeared for about second and as quickly silenced itself and disappeared leaving the blue line, which suggests silenced audio.
I've tried resetting preferences using your link which made no difference unless I have to restart my laptop in which case it still may.
Post by steve » Thu Sep 06, 2012 12:04 pm
snookerjulian wrote:tried to generate tones import and and record new audo within one of these failed projects, and any audio created seems to vanish immediately.
So if you import or record into a new project, then Audacity works correctly, but if you import or record into one particular old project, then the audio disappears? Is that correct?
snookerjulian
Post by snookerjulian » Thu Sep 06, 2012 12:22 pm
If i import to a new project no it doesn't work and if I now try and add to this new failed project it doesn't work.
Recording new music real time to a new project I've not tried recently, I'll let you know. In short I cannot make NEW waveforms from material old or new, I can only work with (and within the confines of) the Audacity projects I had created before this fault.
