Audacity 2 + IZotop Ozon 5
Laovenius
Post by Laovenius » Tue Sep 04, 2012 6:08 pm
Hi! I apologize for my bad English - I am from Belarus. Prompt, set VST plugin Ozone IZotope 5. When it started Audacity 2 plugin does not have the Ok, although in the early Virtue Editor button appears. Without it I can not use the plugin. What to do? How to fix? Thank you.
DVDdoug
Forum Crew
Re: Audacity 2 + IZotop Ozon 5
Post by DVDdoug » Tue Sep 04, 2012 8:59 pm
Audacity can run (some) VST plug-ins, but I really don't know if it runs Ozone...
Most of these expensive plug-ins are not tested & de-bugged by the developer/seller for use with free or low-cost software. The Ozone web site says:
Izotope wrote:Plug-in host compatibility:
Pro Tools, Cubase, Nuendo, WaveLab, GarageBand, Logic, Audition, SONAR, ACID, REAPER, Sound Forge, Peak, Ableton Live, and many more.
And of course, the Audacity developers don't test all of these expensive plug-ins with Audacity either...
Post by Gale Andrews » Fri Sep 07, 2012 2:47 am
Laovenius wrote:Hi! I apologize for my bad English - I am from Belarus. Prompt, set VST plugin Ozone IZotope 5. When it started Audacity 2 plugin does not have the Ok, although in the early Virtue Editor button appears. Without it I can not use the plugin. What to do? How to fix? Thank you.
Can you make a screen shot so we can see the problem? To do this, press PrtScr, open Paint, Paste and save as a PNG image. Attach the image using "Upload attachment" underneath where you post.
If you have to press an OK to acknowledge an unlicensed version of Ozone, but the OK button is off the screen, try pressing ENTER on your keyboard or pressing TAB then ENTER.
