Hey Folks,
I am currently using ver 2.01 on a Dell Inspiron 1545 running Windows Vista. I built Ver.2.01 with ASIO support to try and get around latency issues on this setup. The issue I have is that when using ASIO Audacity only gets input from the built in microphone, ASIO does not seem to understand that there is a front pannel jack for Mic/Line in. Any ideas?
Inspiron 1545 with ASIO
bughunter_ca
Re: Inspiron 1545 with ASIO
What does Windows think in Start > Control Panels > Audio > Recording? Audacity can't do anything that Windows doesn't know about. Koz
