temporary au files
audacitydavid
temporary au files
Post by audacitydavid » Fri Aug 17, 2012 9:05 pm
How to place all temporary "au" files onto a flash drive, not automatically onto hard disk, while recording under Audacity v2.0?
Re: temporary au files
Post by kozikowski » Fri Aug 17, 2012 9:29 pm
Mount the flash drive then start Audacity and tell it to put the files there.
Edit > Preferences > Directories > Temp > Location
Post by Gale Andrews » Fri Aug 17, 2012 9:41 pm
Please help us by posting your question once only and wait for a reply.
