How to place all .au files generated into flash disk?
audacitydavid
After recording from old cassatte tapes, there are a lot temporary "au" files created and being stored into a audio v2.0 temporary folder which I could not find where is this temporary "au" files located under a temporary folder of C: drive of my laptop with Microsoft Window 7 and which will occupy a lot spaces of C:, may be 1 gb spaces for two hour recording. When I colse Audacity V2.0 after I save it into a mp3 file and click "Not Save" button, all these temporary "au" files will be deleted and so they will not occupy huge spaces on C: of hard disk where Microsoft window 7 was installed. Because performing a lot recording in 6 months period and a lot temporary "au" files were being created and deleted on computer's hard disk which causing my hard disk is out of work (died). Therefore, I want to place these temporary "au" files on a flash drive with 8 gb size, cost only $4, while recording so that I do not need worry to make any damages on my hard disk. HOW COULD I SAVE these TEMPORARY "au" files ONTO A FLASH DRIVE before I start recording under Audacity V2.0? I need use Audacity v2.0 its removing noise option to remove a lot noise from the cassatte tapes before converting and saving to an MP3 file. Sorry, I use bold font because of my vision problem. I do not know how to removing bold font after my first posting. Any internet radio stations have radio reading to read best selling books, portry, drama in England, UK?
Last edited by audacitydavid on Sat Aug 18, 2012 10:37 pm, edited 2 times in total.
Re: How to place all .au files generated into flash disk?
Edit > Preferences > Directories > Set Temp Directory and Drive (on Windows and Linux)
Reason: Edit > Preferences > Directories on Windows and Linux
