Fad in control
TBone53
Fad in control
Post by TBone53 » Sat Aug 04, 2012 11:17 pm
Hi folks !
Does anyone know if it is possible to control how quick you are able to bring music up to full volume from a silent starting point?
Cheers in advance for any answers on this!
PGA
Re: Fad in control
Post by PGA » Sun Aug 05, 2012 5:21 am
Effect > Fade In and the Envelope Tool can both achieve fades of any duration you like.
