new Adacity doesn't work at all!
nienke64
Post by nienke64 » Sat Aug 04, 2012 8:12 pm
I've downloaded the new Audacity version, there was just one long line, another recorder was working, althought with difficulty. I've already tried everything! My settings were changed all of a sudden, though I didn't do that myself. I don't understand. I have Vista and I obtained the exe. :(
Re: new Adacity doesn't work at all!
Post by Gale Andrews » Sun Aug 05, 2012 2:52 am
See http://manual.audacityteam.org/o/man/fa ... l#flatline .
If you still need help after reading everything, please tell us what exactly you are trying to record.
PGA
Post by PGA » Sun Aug 05, 2012 5:36 am
nienke64 wrote:My settings were changed all of a sudden, though I didn't do that myself.
Do you use Skype? It takes over your sound system and doesn't always return it to the state it previously had.
