My Audacity 2.0.1 records fine (from LP) for a track or two, then suddenly all I get is white noise and the wave pattern turns into a solid blue bar. I deinstalled and downloaded again when this first happened, but the same problem cropped up again. Any advice?
Walthariu
Recording error
Re: Recording error
If you press Stop and then Record again, does the same problem happen again after a couple of tracks, or once it starts making trash, it stays that way?
