Where'd the volume go?
hellosailor
Post by hellosailor » Sun Jul 29, 2012 8:32 pm
I accidentally recorded boths sides of a cassette transfer into one Audacity file and I figured, no problem, just copy the second half of the file, open a new file, paste in it, save each separately, Bob's my uncle.
Yeahbut.
Even though the waveform in the copied-and-pasted-elsewhere file LOOKED perfectly normal, I could barely hear the music. It was as if someone put the sound down to "1". But I checked every setting, and it wasn't any of that.
Is this because I had two Audacity 2.0 windows, two separate files, open at once? Or am I just lucky hitting bugs today?
I tried working the other way afterward, i.e. deleting half of the large file, saving what was left, and of course that way the file split without any problem.
PGA
Re: Where'd the volume go?
Post by PGA » Sun Jul 29, 2012 8:42 pm
I cannot reproduce that problem using Audcaity 2.0.1 on Windows 7.
hellosailor
Post by hellosailor » Sun Jul 29, 2012 8:49 pm
Obviously, you need to downgrade to 2.0.0 and Vista, and then spend more time trying to reproduce the problem.<G>
Ihaven't had KoolAide all day, I'm sure it wasn't a drug flash.
