delay on second track
guitarman5634
hi im useing 2.0.0 ,windows7,alesis multimix 8 board,when i record the first track it works perfect,but when i record the second track like drums elrctronic,one line in to the board i get bleed through and bad delay,what have i done wrong
Re: delay on second track
I assume you're trying to do multi-track overdubbing?
http://manual.audacityteam.org/help/man ... rdubs.html
Sometimes, when you're recording from Stereo-Mix or What-U-Hear to get internet sound, you leave those settings for live recording. Bad idea. You have to record from a specific device like Line-In or Mic-In. You will also run into delays and echoes you can't fix without special hardware.
