Measuring Power
conexor
Measuring Power
Post by conexor » Thu Jul 26, 2012 1:27 am
Hi All,
Is it possible to have audacity integrate the area under the frequency analysis curve so that it produces a number giving the total power?
If so, is it further possible to band limit the integration so that we only get the power between two specified frequencies?
See the attached picture.
And the big question.
How does one do it.?
Thanks in advance.
Screen shot showing audacity frequency analysis
Audacity Screen spectrum.png (134.88 KiB) Viewed 481 times
Re: Measuring Power
Post by steve » Thu Jul 26, 2012 2:25 am
You would need to export the Spectrum data as a text file (Export button), then import the data into a spreadsheet for further analysis.
