Pre Sonus Audiobox
rj7500
Pre Sonus Audiobox
Post by rj7500 » Wed Jul 25, 2012 6:50 pm
Is this verson compatible with the PreSonus Audiobox ?
Bob H
ragnar.jensen
Re: Pre Sonus Audiobox
Post by ragnar.jensen » Wed Jul 25, 2012 6:59 pm
This one?
Yes, I use it all the time with Audacity.
Ragnar
