System Reboot
Stephan1953
System Reboot
My Laptop needed a reboot to default! I re-installed my Disc for the V-1.2 But I couldnot get the Lame software to work! now I downloaded the new V2.01 but the default preference is only Mono How do I get the Stereo preference, in this new version?
Stephan1953
Re: System Reboot
P.S I am using Windows VIsta,
Stephan
Stephan
Re: System Reboot
Normally you would set the number of channels in the Device Toolbar: http://manual.audacityteam.org/man/Device_Toolbar
Stephan1955
Re: System Reboot
Please forgive the change in username but I had trouble logging back in!! I tried the device manager but it doesn't change! It has only the (1)mono in the dropdown box!
Stephan
Stephan
- Quality Assurance
Re: System Reboot
Follow the steps in the green box "Operating System Specifics" here:Stephan1955 wrote:Please forgive the change in username but I had trouble logging back in!! I tried the device manager but it doesn't change! It has only the (1)mono in the dropdown box!
http://manual.audacityteam.org/o/man/re ... html#setup
- Quality Assurance
Re: System Reboot
If this is still a problem, download the correct LAME v3.99 .3 here:Stephan1953 wrote:I couldnot get the Lame software to work!
http://manual.audacityteam.org/o/man/fa ... .html#lame .
Stephan1955
Re: System Reboot
Dear Gayle
Thank-you very much, I will try the lame I already have and if it doesnt work I'll come back here and download it again.
Stephan
Stephan
Stephan1955
Re: System Reboot
Dear Gayle,
Thank-you very much, I Guess the "Lame 3.99" works best with the latest version of "Audacity"! The
CD that came with my record player only had the Version. 1.2! My records never sounded better, No Scratches and I can even amplify the volume before saving ,
Thank-you once again!
Stephan
Stephan
- Quality Assurance
Re: System Reboot
Audacity 2.x (and 1.3.7 and later in the previous Beta series) need LAME to be built with sufficient features (symbols) or they won't accept LAME. This is so that the MP3 exports with reasonably correct metadata and correctly reported playing time, and so on.
You can always get a full featured LAME from the links we give, but versions of LAME downloaded elsewhere may not have enough features turned on.
