when i export a file to mp3
and then go to the file exported,
it shows a small lock on it- so i cannot open it.
also, when i record or play back a file coppied from a cassette, it sounds like a growing noise
please help...
my windows is windows7 and the installation cd says: Ver 47.0A
mp3 files exported show a lock sign
Re: mp3 files exported show a lock sign
Will it let you right-click the file > Properties?
Distortion that slowly changes over time could be Windows Enhanced Services, their conferencing suite. You can turn that off.
http://manual.audacityteam.org/help/man ... hancements
How do you have the cassette machine connected to the computer? Most people get this wrong because the computer suggests strongly that you just run a wire between the tape player and the computer. It's usually not so simple.
http://manual.audacityteam.org/help/man ... to_cd.html
