Audacity LINE IN not recording . . .?
monkeyboyblues
Re: Audacity LINE IN not recording . . .?
is the mic input the input ?
The Mic input is an input, however it may be too sensitive for plugging a digital recorder workstation into it.
Some laptops have "mic inputs" that are actually combined "mic" or "stereo line" inputs. If the laptop has one of those then that will work.
Some laptops have "mic" inputs that are only for microphones. If your laptop has one of these then the sound will distort and only be in mono, in which case you will need to buy an external "line in" device (such as a Behringer UCA 202 which was suggested earlier).
