How to display time format to second-format?
hnQ
Post by hnQ » Mon Jul 23, 2012 9:28 pm
Hi, how do I display the timer to be seconds only, not the current minute-and-second format
Re: How to display time format to second-format?
Post by steve » Mon Jul 23, 2012 11:02 pm
Do you mean in "Timer Record"?
The time format there is not adjustable.
