hi
when is it a good time to normaiize a song?
coonsanders
when to normalize a song
coonsanders
Re: when to normalize a song
What are you calling a "song?" Something you downloaded, or something you just sang?
coonsanders
hi
these r 78 audio files that i want to clean up..
Ah. We wrote a lot of good stuff on how to do this.
http://manual.audacityteam.org/help/man ... to_cd.html
By far the best thing you can do for 78s is play them with a 78 stylus and at the right speed. a 33-1/3 needle will sit on the bottom of the grooves and pick up extra noise and speed changes are never perfect. All that's over and above the music quality and cat hairs.
coonsanders
thanks..
lenny
lenny
