Having a HUGE problem looping music!!Please help!!
phillip2600
Post by phillip2600 » Sat Jul 21, 2012 7:11 pm
Hi I am new to audacity.I just cannot get music to loop perfectly.It is driving me insane!!!I have tried to loop perfectly using a different program,and sometimes it works,but it usually doesn't.So I tried audacity and I still cant get music to loop perfectly.Here is the music I am trying to loop:http://www.youtube.com/watch?v=zu2vh3QbntE I am trying to loop the first 27 seconds of this.In you guys opinion is this a difficult piece of music to loop?Should it be?In general how do you loop music perfectly?I actually looped this perfectly a while back using a different program,but I must have simply gotten lucky because since then I have probably tried looping this 25 times since and it hasn't worked.Some help would be greatly appreciated.
phillip2600
Does THIS MUSIC sound like it would be diffucult to loop?
Post by phillip2600 » Sat Jul 21, 2012 7:17 pm
Here is the music:http://www.youtube.com/watch?v=1K1rV9kFs6I I am trying to loop the first 19 seconds.In you guys opinion,should this be a difficult section of music to loop?Just how hard or easy does this sound like it would be to loop?
phillip2600
Does this sound like a perfect loop?
Post by phillip2600 » Sat Jul 21, 2012 7:48 pm
Here is me trying to loop some music:http://soundcloud.com/phil2600/thunder-hop What do you guys think?Does the loop sound perfect?I'm not sure.
Re: Does THIS MUSIC sound like it would be diffucult to loop
Post by Gale Andrews » Sun Jul 22, 2012 2:00 am
If you have any more questions on this exact topic please post them here, not start new topics. You can press "POST REPLY" in an existing topic (at the bottom) to add another question.
Thanks for your assistance. As for your question, try reading http://wiki.audacityteam.org/wiki/Looping - you can't loop MP3 because of the padding, but you can WAV.
