Installing Audacity 2.0
I am trying to install Audacity 2.0 version on my Windows 7 and got an error saying "an error occurred while trying to read the source file invalid floating point operation". how do i correct this problem? thanx in advance for any help.
Re: Installing Audacity 2.0
I'm not on Windows, but we did publish a good wiki on installation problems.
http://manual.audacityteam.org/o/man/fa ... g_ins.html
thank you. i will check that link.
