Converting a stream to a file
kenw100
Post by kenw100 » Sat Jul 21, 2012 4:31 pm
How do I convert a stream into a file that I can listen to on my MP3 player? This is not copyrighted stuff. I use Windows 7.
Re: Converting a stream to a file
Post by kozikowski » Sat Jul 21, 2012 6:10 pm
You can capture the stream (in real time) and save it as a file. Streams are intentionally prevented from bulk downloading (as a rule), so you can't get an hour show in eight seconds. This is also assuming the show isn't available as a podcast which is far easier to deal with than live capture.
http://manual.audacityteam.org/help/man ... puter.html
kenw100
Post by kenw100 » Sun Jul 22, 2012 1:34 pm
Do you have any suggestions on a third party stream recorder that might work for me? I use Windows 7 and the computer manufacturer (Dell) told me that there is no such option for me on this computer and that I would need a third-party option for this to work.
Post by Gale Andrews » Sun Jul 22, 2012 6:28 pm
kenw100 wrote:Do you have any suggestions on a third party stream recorder that might work for me? I use Windows 7 and the computer manufacturer (Dell) told me that there is no such option for me on this computer and that I would need a third-party option for this to work.
Read "Alternative programs for recording computer playback" at the bottom of this page:
http://manual.audacityteam.org/o/man/tu ... ndows.html .
