Can't precisely select spot in waveform
kenw100
Post by kenw100 » Sat Jul 21, 2012 4:25 pm
When I try to select a spot in the waveform the cursor jumps a little bit to another location. I can't seem to precisely select what I want to. What can I do to stop this?
Re: Can't precisely select spot in waveform
Post by kozikowski » Sat Jul 21, 2012 6:13 pm
Look to the bottom of the work window and make sure "Snap-To" is turned off.
kenw100
Post by kenw100 » Sun Jul 22, 2012 1:29 pm
thanks!
