Steps 4, 7 and 14 of the Audacity Guide.
[email protected]
Post by [email protected] » Sat Jul 21, 2012 2:45 pm
There is no provision for my input or output device. I tried all that are provided (Scarlett 2i2 is not provided). Nothing results in a recording being made.
[email protected]
Audacity Guide
Post by [email protected] » Sat Jul 21, 2012 3:28 pm
Re. steps 4,7, and 14, my preamp device (Presonus) later showed up as a choice; therefore, disregard the previous inquiry. Thanks.
Re: Steps 4, 7 and 14 of the Audacity Guide.
Post by kozikowski » Sat Jul 21, 2012 6:20 pm
I would not have posted my email address. We get a great many bulk mail harvesters and you may find your address unusable.
Is your I/O device listed in Windows Control Panels? If Windows can't find it, Audacity can't, either. Also, Audacity has two places to select devices, the Device Toolbar on the front and Audacity > Preferences > Devices inside. Do either work?
Do the software packages included with the device work?
[email protected]
Post by [email protected] » Sun Jul 22, 2012 12:05 am
Topics merged
Thanks. See my second message.
