Audacity 2.0 & Windows 7
Banksy2412
Post by Banksy2412 » Thu Jul 19, 2012 9:28 am
Hi
I have loaded Audacity 2.0 to my Sony Vaio laptop but I cannot see Audio Devices when I got into my control panel only Sound, so I cannot complete the final part of the set up which will allow me to record from vinyl.
Has anyone out there ever had this problem and if so, what did you do to resolve?
Thanks in advance for any help/guidance.
Re: Audacity 2.0 & Windows 7
Post by steve » Thu Jul 19, 2012 10:21 am
Check that the input that you want to use is enabled in Windows: http://wiki.audacityteam.org/index.php? ... es#vistacp
After enabling any new devices, restart Audacity or select "Rescan Audio Devices" from the Transport menu.
