how to make concert hall effects
hushinimi
Post by hushinimi » Tue Jul 17, 2012 7:48 pm
before that, hi there I'm new in using audacity :) great program though I am knowledgeable in this kind of software :(
if anyone has a realtek HD audio manager(I am sure most has it) and if you set the sound effects environment to concert hall, it sounds amazing! though I can't figure out the setting's to get that sound :(
kindly help me please , thank you in advance!
Re: how to make concert hall effects
Post by steve » Tue Jul 17, 2012 10:25 pm
Open the Realtek HD Audio Manager and select the effect that you want from the "Sound Effects" tab.
hushinimi
Post by hushinimi » Wed Jul 18, 2012 3:01 am
thanks for the reply! yes I know how to do that, but How do I record it if possible in my computer? since I don't have the hardware to record :?
or should I say, how to do I produce a new file that sounded just like the concert hall in the Realtec hd audio manager?
Post by steve » Wed Jul 18, 2012 1:28 pm
The affect you are after is reverberation and/or echo. See here: http://manual.audacityteam.org/manual/h ... on_or_echo
hushinimi
Post by hushinimi » Wed Jul 18, 2012 2:41 pm
thank you very much ! helped alot ! now I need to find the best equalization to make the sound more whole and solid :) thanks a bunch mr.steve! ;)
