don have permission
billybob716
don have permission
Post by billybob716 » Fri Jul 13, 2012 9:56 pm
c:progam file(x86)audiacitythe movie audio you do not have permission to save in this location contact the administrator to obtain permission i down loaded using .exe installer how do i fix this problem i do have the latest version plus i am running a windows 7 please can someone give me some advice thank u
Re: don have permission
Post by steve » Sat Jul 14, 2012 2:07 am
Try saving to "My documents".
User data should not be saved to c:progam file(x86)
