8KBPS (Super Compressed Audio?)
MichaelWR90
Post by MichaelWR90 » Thu Jul 12, 2012 12:50 pm
Good morning,
I have a few files, 8kbps is the only thing I see in properties.. One is 500KB in size and it says it's 8 minutes long. I can't play them with ANYTHING. Anyone have an idea how I may be able to get these to play?
Thanks!
Re: 8KBPS (Super Compressed Audio?)
Post by steve » Thu Jul 12, 2012 3:18 pm
MichaelWR90
Post by MichaelWR90 » Thu Jul 12, 2012 3:25 pm
No luck with VLC :(. I tried everything, Audacity seems like it can do some type of conversion to make it work.. Just don't know where to start.
Post by steve » Thu Jul 12, 2012 3:31 pm
Audacity is not a particularly good format converter.
Last ditch chances:
SUPER (free but quirky and lots of links before the download page)
dBPowerAmp (free and paid version)
MichaelWR90
Post by MichaelWR90 » Thu Jul 12, 2012 3:55 pm
Nothing on either of those either.. Damn these are some serious compressed files, lol.
Post by steve » Thu Jul 12, 2012 4:06 pm
MichaelWR90 wrote:8kbps is the only thing I see in properties
Where are you seeing that?
Post by steve » Thu Jul 12, 2012 4:11 pm
MichaelWR90 wrote:and it says it's 8 minutes long
and where's it say that?
MichaelWR90
Post by MichaelWR90 » Thu Jul 12, 2012 4:38 pm
This dBpoweramp gives me more details :)
Right Click, Properties, Audio Properties
Size 491 KB (94% Compressed)
Original Size 7.67 MB
Length 8 minutes 22 seconds
Channels 1 (mono)
Sample Rate 8 KHz{CR}
Sample Size 16 bit
Bit Rate 8 kbps
Encoder
Encoder Settings Unknown ACM ID: 41220 (ACM decoder not installed)
Audio Quality Low (Lossy)
Contains
Channel Mapping Center
File Davenport_01-Dec-2009
Type Microsoft Wave Sound Format [.WAV]
Post by steve » Thu Jul 12, 2012 5:29 pm
MichaelWR90 wrote:Encoder Settings Unknown ACM ID: 41220 (ACM decoder not installed)
That's your answer.
You need to obtain, and install system wide, the ACM decoder, ID: 41220.
From what I can find from Google, this appears to be a proprietary codec from "Verint".
Sorry I have no more information, but please do let us know if you are able to resolve the issue.
