basic installation of stanton keyboard
cecie
Post by cecie » Sat Jul 07, 2012 8:21 pm
I am trying to connect a Stanton (T.92 USB) turntable to my Lenovo computer (Windows 2011). Just downloaded Audacity 2.1 from website but setting/install instructions don't match what I am seeing. Can't get recording to work. Thanks.
Re: basic installation of stanton keyboard
Post by steve » Sat Jul 07, 2012 11:48 pm
Which "install instruction"s are you looking at? These ones? http://manual.audacityteam.org/manual/h ... ables.html
What exactly is the problem?
